05-02-2026 06:56 PM
Hi,
I got message from public mobile (#5474) on March 30 and ask me to reply YES1, if I am interested for 4G, 3 GB plan for $19 per month. When i replied YES1 on April 6, I got confirmation that from your new subscription plan will be added to account and will effect on your next renewal date.
My new renewal date started on Apr 30 but i didn't see the new subscription plan in effect.
Does Any one has any idea.
05-10-2026 12:24 PM
05-10-2026 12:20 PM
Ticket has been generated before a week. No reply from public mobile.
I can't understand why public mobile not able to answer or reply even after a week.
Regards,
Bankim 1
05-04-2026 08:04 AM
Hello @ Bankim1,
I sent you a private message. You can view it by accessing this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
05-03-2026 11:14 PM
I have escalated your ticket on your behalf. PM support will reach out to your via Community inbox. Please monitor here for their reply:
(Since it is a bit late tonight, they might not reply you until tomorrow morning)
05-03-2026 11:07 PM
Hi,
I checked my usage breakdown. I didn't see the new subscription plan, same as old one.
Can you please help me to figure out.
Best regards,
Bankim
05-03-2026 05:58 PM
I had the exact same problem with a 5474 offer & it took 1 month to get it resolved....
The update "froze" my account on the app & web site but the agents saw the renewed plan; not all what I was seeing...they told me to update the app & then I just had a blank screen when I opened the app...just the refresh circle & the site told me I had an Internal Sever Error, try again later....
Always mention the 5474 offer each time you are dealing with the agents because that is your starting point....it took 4 app updates before they could get it working....
Makes me leery about accepting another offer from 5474...
Hope you have a faster resolution than I did...
05-02-2026 08:16 PM
If renewal days was April 30th, you should see your new plan noted there now. Log in to your account using the app, tap Usage Breakdown and you'll see the plan as of latest renewal. Let us know if you don't see it like that.
05-02-2026 08:01 PM
@Bankim1 The new plan will take effect on your renewal date not immediately so you don’t lose $ on your current cycle
