Roaming data nag messages
Gerskan
I have a current US & Canada plan. I have traveled to US before with few Public Mobile issues. I have been in the US for over a month and get many nag messages daily about roaming data. I have used less than 1GB of my 50GB. How to stop the annoying and pointless nagging?
@Gerskan wrote:  Any other suggestions?
It's been a coupla years (Jan 2025) since I traveled to US but I also used to got that nag when crossing the border...never got it whenever initiating a call while in US. The only suggestion I can provide is a long-shot...try restarting your cell. If that fails, try a network re-set. Hopefully something helps.
ed...as you and wife have same cell...do a side by side comparison of settings. Make yours same as hers.
Gerskan
Thanks for responding. My wife and I have same plan and same phones. We both received notifications on US arrival. On previous trips this nagging did not happen. I am the only getting nagged each time I attempt to use my phone. I have turned off App notifications; still nagging.  Any other suggestions?
hairbag1
@Gerskan
been that way for years...just ignore as you already have what you need with your regular plan. Make sure to enable Roaming to be able to use data while in US.
added...don't know if this would help; use the app to log in to your account > Account tab (bottom of page)...scroll down to find and click Notifications...see if you can stop that nag by selecting Never.
Hope this helps you.
