07-15-2021 08:31 AM - edited 01-06-2022 03:01 AM
Hello, I had a Huawei Mate 20 Lite for the last year or so and have been using Public with no problem. I just bought a Oneplus 7 Pro and put the same sim card into it. Texting and calling works like a charm but I cannot use my mobile data at all.
The device activation brought me to the mobile data portion and it will not let me finish it. It says, "Activation Incomplete This device has not been registered with an account. Please contact your service provider to activate this device for network service." I cannot contact
Public through the phone, so I don't know how to fix this. I have a Oneplus account on the device as well so I am dumbfounded as to what the problem is.
If anyone knows a fix, thank you.
07-15-2021 09:29 AM
I updated the phone and was able to edit the MVNO type. This fixed it. Thanks to everyone!
07-15-2021 09:03 AM
For some reason the OS...Android 8 or 9 will grey out the APN on certain international phones once a sim card has been inserted it locks the APN to that provider. ( Was this an open box or refurbished purchase?) There are two ways to install pm's APN....
07-15-2021 09:02 AM
@ApexFullsend173 is that Dual SIM phone?
Do you not have a "+" button to add APN's?
Settings > Wi-Fi & Internet > SIM & network > SIM 1 (or 2)
under "Network Settings" there is "Access Point Names" and tapping that shows the APN's currently setup. The top has a + search (magnifying glass) and vertical ellipsis (3 vertical dots). You can edit an existing APN or tapping the + allows you to add (if you don't see the + then press the ellipsis and see if there is an add option).
After inputted the values, press the ellipsis to Save you entry! Don't just press the back arrow, you changes or new APN will not be saved and you'll have to redo it.
07-15-2021 08:45 AM
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
07-15-2021 08:45 AM - edited 07-15-2021 08:46 AM
You should be able to edit your APN on that brand and model of phone. What is the OS? Is there a software update available? Connect to wifi and check.
07-15-2021 08:41 AM
07-15-2021 08:40 AM
Brand new phone off Amazon says it works with PM in the description. The APN settings are greyed out so I can't change them anyway I've tried. The MVNO type is set as something different from what I have seen though. I will send a SS of my apn settings
07-15-2021 08:35 AM
Sorry to hear you're having issues w/ the OnePlus on PM.
Is it a brand new phone? Refurbished? Used?
Could be related to the APNs. Someone else posted this: https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/No-Data-on-One-Plus-7-pro/td-p/443052
Hope it helps!
07-15-2021 08:35 AM
Can you post a screenshot of your APN settings ?
