a month ago
Not sure when this has happened, but I can no longet send and receive pictures through MMS.
I have been on the site and edited my settings to what it says and rebooted the phone and still fails to send.
Is there something wrong with my account?
Service
a month ago
It works now! It was the all caps SP.MB.COM that got it working
a month ago
@Tmclunn1 Did you try with the line SP.MB.COM in all caps? Seems to be a OnePlus thing.
a month ago
@Tmclunn1 make sure no error in the entries. Sometimes there is error and hence you cannot enable it
worst case, Reset All Networks and it will wipe the manual profile and restore the default one. You can then manually recreate a new one again
a month ago
I sure did and rebooted a number of times
a month ago
@Tmclunn1 did you delete the current one and create a new one? with one APN Profile, it will use it as default or you should be able to enable it
a month ago
Followed what you said. Couldn't flip that enable switch though for the apn.
Still doesn't work.
a month ago
no worries it will work
But qith OnePlus, there might be a bit more work than simply updating or turning on and off the network. Many confirmed that you need to delete the current APN profile first. Then Add new profile and add according to this, please note case-sensitive and do not add extra spaces. Remember to save the new APN and then reboot the phone before you try
APN: sp.mb.com
(or try all upper case SP.MB.COM)
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
(or try: http://aliasredirect.net/proxy/mmsc)
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
(might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
a month ago - last edited a month ago
@Tmclunn1 wrote:I'm using a OnePlus 7T
I set it up as per what you said. Still fails.
Hello @Tmclunn1
This may sound weird but it worked for a buddy of mine. Go into your network settings, turn off automatic and pick Public Mobile as your service. Then reboot the phone. Then try to send those messages.
EDIT: If that doesn't work, I don't think it's going to work for you. I remember something a while back that has to do with APN settings is on the ROM itself and every time an upgrade happens, it refers to the ROM not to what PM APN is... might need to check OnePlus forums on how to fix that. But I'm an iPhone guys so...
a month ago
a month ago
hi @Tmclunn1
what phone are you using?
Telus (PM) has retired some legacy servers and old phones from 2017 before will be affected
and check if you have these APN settings
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
a month ago
make sure mobile data is turned on, and Reset Network Settings and you can try again
