Receiving images via text
Chatbotssuck
I cannot send or receive images to about half of my contacts (who use both android and apply devices). Help would be appreciated
I checked this page and tried setting a new APN settings based on the suggestion there, to no effect
Forum post
https://productioncommunity.publicmobile.ca/t5/Get-Support/Re-Unable-to-download-pictures/td-p/42431
Solution posted in above thread
https://apn.how/ca/public-mobile#google_vignette
I have an android, one plus, model NE2215, running oxygenOS 1.4
2 REPLIES 2
Chatbotssuck
Thanks for the suggestion. The automatic settings looked fine, but I tried regardless. No improvement, unfortunately
Chalupa_Batman
Forum post
Hello @Chatbotssuck
This worked for my buddy who's on Android so I hope it works for you as well.
Go into network settings, reset your network settings and then go carrier I think? And turn off automatic and choose Public Mobile and then reboot. This worked for him at least.
