02-25-2023 10:02 PM
Hi. I'm new to this. My account says I'm active. It says a payment was due Feb 26. That's tomorrow and I am on auto pay and I checked card and it is current. Not sure what is going on.
Service
02-25-2023 10:39 PM
Will do. Waiting for reply
02-25-2023 10:39 PM
HI @Moose3 let us know what PM support found and if they can fix it quickly
02-25-2023 10:36 PM
@Moose3 Let us know how you make out with support and what they say issue is.
02-25-2023 10:32 PM
Thanks
02-25-2023 10:31 PM
Thanks waiting for a reply
02-25-2023 10:30 PM
Yes
02-25-2023 10:29 PM
Airplane mode is OFF...right ?
02-25-2023 10:26 PM
@Moose3 if you have another phone, test your PM sim card there. It would force a sim reprovision and it could resolve your problem
if still does not work or you don't have another phone around , open ticket with PM Support
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
02-25-2023 10:24 PM
@Moose3 I suggest contacting support with the links in my last post have them investigate for you
02-25-2023 10:24 PM
Thanks
02-25-2023 10:23 PM
Tried all of the above...nothing
02-25-2023 10:23 PM
Yes has been working fine. Bluetooth off.
02-25-2023 10:22 PM
HI @Moose3 so, it shows connected to Public Mobile network?
Text working but not phone calls?
do you have another phone to test the sim card?
or did you try your phone in different area?
02-25-2023 10:22 PM
Also tried network settings
02-25-2023 10:17 PM
I've rebooted
02-25-2023 10:15 PM
@Moose3 If all else fails contact support to investigate
- Get support by starting a conversation with virtual Chat box /SIMon. Click here
- you can send a private message To CS_Agents by clicking here.
Watch for reply top of page to the
Right ( envelope image )
02-25-2023 10:14 PM
@Moose3 wrote:i have tried in another phone. I can receive text messages
@Moose3 can you only send and receive text? does mobile data work?
What plan do you have ? $15 or others?
how about incoming calls or outgoing?
if $15 plans, can you login My Account again using Incognito mode and check if you still have outgoing minutes left?
If you still have outgoing minutes or if you are on $25+ plan , try to change your Preferred Network type or Network mode to 3G only or WCDMA and check if the phone connects at all under this setting. If it connects, try to make outgoing calls again
02-25-2023 10:14 PM
that's odd...has it been working fine up to now ?
BTW...make sure you haven't turned ON bluetooth by mistake...maybe calls are going through your car !!
02-25-2023 10:12 PM
@Moose3 Try rebooting the phone . Or you can also try resetting the network settings
02-25-2023 10:11 PM
i can't talk or receive calls.
02-25-2023 10:10 PM
@Moose3 Also check that you still have data a minutes left are you in the $15 plan by any chance ?
check like this
when logged in
02-25-2023 10:10 PM
02-25-2023 10:08 PM
as long as you can still talk/text/data...just ignore the Suspended message. As long as you have a valid credit card on your file set to Autopay...all should be fine tomorrow am.
Check to make sure you can still text or talk.
02-25-2023 10:06 PM
@Moose3 Can you try the SIM card in another phone and see if services are working
