07-24-2022
02:32 PM
07-24-2022
09:19 PM
Dunkman
I can’t make or receive calls in the US and I’ve purchased the roaming package. It keeps coming up “dial assist” on my phone.
10-25-2023 09:04 PM
Thanks, that worked
07-24-2022 04:55 PM
07-24-2022 03:34 PM
What city/state are you in?
07-24-2022 02:50 PM
Dial assist? Are you including a 1 in front of the numbers you're trying to call?
Did you possibly buy two different talk parts?
07-24-2022 02:39 PM
Hi @kaylavv are you manually connecting to AT&T or TMOBILE? Try T-Mobile, voice can work on its 2G as well as 3G network
07-24-2022 02:37 PM
The issue with Public mobile US roaming at the present time is the decommissioning of 3G Networks in the USA. Public mobile uses AT&T and T mobile as their US partner carriers. AT&T already phased out 3G network earlier this year. T mobile 's date was July 1. It may take time for the different areas in USA to decommissioned.
According to Public mobile,
PM will have T mobile 2G network for US roaming.
Voice and SMS text will still work.
Data will work on LTE, but will switch over to 2G to make a call.
However, the quality of service will vary depending on the different coverage areas when roaming in the USA.
Public mobile is working on a long term solution, but that will take time.
Here is some more info:
https://www.publicmobile.ca/en/on/get-help/articles/us-roaming
