06-30-2024 01:46 PM
Ringtones are audible when calling another mobile phone. With landlines, there is only silence until someone answers or it goes to voicemail.
06-30-2024 06:20 PM
That's what I have done. I'll wait for that reset and see if it solves the problem. If not, I can live with it. Thanks for your quick replies.
Stu Clark
06-30-2024 06:17 PM
I think you can ask PM to reset your account on the system and maybe it helps
open ticket with PM using the Orange Chatbot icon on the lower right. Type the question Submit ticket and select Contact Us to get to ticket open screen
06-30-2024 06:15 PM
Thanks for the walk through. I reset my network as you directed but the problem persisted. My wife's iPhone doesn't have the problem. I can't see any phone setting that mutes ringing for landlines only. Cellphone still have the normal ringtone when called.
06-30-2024 03:00 PM - edited 06-30-2024 03:03 PM
The only other option I can think is for you to reset your network settings. Go to Settings > General > Transfer or Reset iPhone > Reset > Reset Network Settings. This will erase all current saved settings, including Wi-Fi passwords, preferred networks, and VPN and APN settings that you've used before. Then reboot. Try to call a land line again.
The only other option if that doesn't work is to create a ticket and ask Public Mobile to reset your network from there end.
To Submit a ticket, please click the following link to access the Public Mobile Chatbot: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type: Customer Service Agent
06-30-2024 01:57 PM
Thanks for the quick response! I am using iOS 17.5.1. The problem has persisted through a few updates now.
06-30-2024 01:51 PM
I get that with my iPhone SE 2020 as well sometimes. Check to make sure you have the latest software/firmware update from Apple.
06-30-2024 01:49 PM
did you try using another mobile to call that landline? just want to tell if you got the same
maybe try another Telus or Koodo mobile phone. But sometimes, i could be a landline problem, mobile phone take more hops to get to another mobile carrier , that could be why
