06-30-2024 09:03 PM
Is it possible to get a day or two of calling in the US? What if you are travelling to the US for a few days and want to make calls?
06-30-2024 09:15 PM
Those apps can let you make calls, but you need an internet connection for them to work. So if you're trying to make or receive calls while outside or not connected to Wi-Fi it might not work for you.
06-30-2024 09:09 PM
@slusagm thank you for the suggestion I'll have to look into this
06-30-2024 09:07 PM
no such plan @Dolphin12 if you wnat to make calls free in US, use VoIP app. You can check TextNow or Fongo
06-30-2024 09:06 PM
Thank you @golfball I wasn't sure if there was a plan less than 15 days
06-30-2024 09:05 PM
You can buy a roaming add-on that lasts 15 days, there's nothing shorter than that.
