yesterday
I bought a plan that says "50GB Data within Canada and the US at 5G Speed" specifically for travel to the U.S. When I crossed the border, I didn't have any useful connectivity.
I have an iPhone 14 Pro and I checked my settings to make sure that data roaming was enabled but my phone showed SOS access only the entire time I was in the states.
What should I try or should I just switch to another provider?
15m ago
Also enable VoLTE for calling in the US.
49m ago
Thanks for the link. I'm not in the US and, unfortunately, couldn't access any troubleshooting information on my last trip because I didn't have data. I'll try the manually selecting a network the next time I cross the border to see how that works.
an hour ago
You are right. It should have worked properly. Are you in the United States right now? Public mobile uses AT&T and T mobile as their carriers. Supposedly, Verizon also should work now.
Here is some more troubleshooting advice:
https://www.publicmobile.ca/en/ab/get-help/articles/us-roaming-troubleshooting
