Canada-USA-Mexico
Me14
Is there a limit to the number of days that the plan can be used in the USA or Mexico.  I will be going to the US for 7 months.  Can I use it for 7 continuous months, or do I need to use the plan more in Canada?
10 REPLIES 10
hairbag1
@LisaCaballero
to use your cell for talk in USA, you must have a cell that is VoLTE recognized by Public Mobile...not all VoLTE cells are. VoLTE isn't mandatory in Mexico...just USA. Here's a bit of reading with a device checker at the bottom of the page.
https://www.publicmobile.ca/en/get-help/articles/volte
You must enable roaming for data use outside of Canada.
slusagm
With Canada US Mexico plan, you can use data in all 3 countries.  You can send and receive calls within the 3 countries for free.  and you can text in all 3 countries for free
@LisaCaballero wrote:
With a CANADA-US-MEXICO plan, does that mean I can just take my phone across the boarder and continue to use it as I would in Canada?
Yes. That's exactly what that means.
hi @LisaCaballero
yes, basically you are using the service in US and Mexico like you are in Canada.
porcupine
It does not say anything about a time limit any ware
@Me14
All we can say is there is no writing about any limit, and we didn't hear anyone reporting back about the limit
So, I would say it is safe to use it in US continuously
