Dropped calls
Kelly3633
Hi, while talking on my phone, the call drops/disconnects randomly, several times a day. Is there a fix for this? When I joined Public Mobile in 2022, this did not happen. Started this year (2024).
I also notice, when on fb that it says, 'you are not online', or words to that effect, then ' your internet has been restored.' Happens constantly.
Chalupa_Batman
Hello @Kelly3633
Please create a ticket to get Public Mobile to reset your network. Both of my neighbors are having the same issues.
To submit a ticket with CS Agent using this Chatbot link
Type Customer Service and follow the prompts. If you are having any issues, here is a direct link by sending a private message
slusagm
what phone you have? maybe VoLTE problem? did you try using 3G for voice? See the network mode to 3G only
or on your phone, try Reset All Networks
eddieO
@Kelly3633 I would check the Telus outage map for you area to see if there is something going on. If you have access to another phone try installing your SIM card in it (reboot the device after doing so) and see if you are still having problems. Another thing you can try for a test is go into your phone's setting and change it to 3G and see if it makes an improvement. Are you finding this happens at home, work, anywhere specific?
Telus Outage Map: https://istheservicedowncanada.com/status/telus/map
TELUS Service Status: https://www.telus.com/en/qc/outages
