Help me with registration
gobblewobble_
So on my play store It says I don't have the app in my country and I can't change it in settings so I was wondering if I put the sim on my phone can I register it on my iPad?
2 REPLIES 2
Chalupa_Batman
What this is telling me is your Play Store and even maybe your phone is registered in another country other than Canada. You should consider signing up for a new account on your phone locally to where you are.
If unable to do so, please check your email box here.
slusagm
for iPad,  you should use a phone to register the sim first as you need to confirm your account once after the account is activated
so, check if you can find a phone with Canada as the country.  Download the PM app there and activate the physical sim. After account is setup and functional, use a web browser to login the account once more to get the Confirm registration done ( they will send you a 2FA text to the phone.  You need a phone to complete that part once as iPad cannot receive text).  Once that part is also done, move the sim card to iPad
