I recently upgraded my service to include canada, usa and mexico. Now I can't make a phone call anyw
Daniel56
Can you fix this.
Hi @funpig1 no need to tag me.  I was not the one with the problem
funpig1
@Daniel56
Did you change on renewal? Perhaps, your payment did not go through and your service has been suspended. At least three people have made the same complaint that their payments were not accepted by PM and their service has been suspended.
Try all the advice below (reset network, reboot etc). If still not work, message a customer agent and queue up for assistance for what is probably a system issue. Good luck.
Yummy
Where are you currently?
Can you receive calls and send/receive SMS?
slusagm
Are you in Canada now or US or Mexico?
Try calling with a 1 then the 10 digits
And Reset Network Settings on the phone.  Try your sim card on another phone as well
If course , if issue persists, ask PM to check.   Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.)  Type the question Submit ticket and select Contact Us to get to ticket open screen
Or message them using this link:
