a week ago
- last edited
a week ago
computergeek541
I googled the problem and tried trouble shooting but my phone seems to be set up the way it should w LTE and roaming on. It worked for one day without issue and all of a sudden does not work today. My family who also have an account can call me but I cannot call them. Any advice on how to fix?
Thursday
Ah yeah, that's the issue then. It's fine I'm Canada because your phone will fallback to 3G to make phone calls. The US shut their 3G networks down a couple years ago, so that's not an option there; instead you need to be able to use VoLTE, which your phone cannot.
If you were able to make a phone call in the US on this trip it's likely because there was a T-Mobile 2G connection in that area. You could try again to search for 2G networks, but those towers are few and far between.
Thursday
Thanks for your help. I have a Google 3XL. Phone is no longer supported for updates. I guess that is why. Works fine at home and worked for one day here but no longer.
a week ago - last edited a week ago
What phone do you have? And have you ensured the software on it is up to date?
a week ago
Which model phone?
Certain phones (international, older phones) have recent issues with voice due to PM adjusting the 3G bands on certain areas.
a week ago
You are in US?
Try to call them by +1 then 10 digits. or 1 then 10 digits or #1 then 10 digits
a week ago
@ekng008 , it is hard to say what is going on. It would appear the problem is with your phone. US roaming requires a VoLTE capable device for both outbound and inbound calls. If one works, the other should as well.
