Can receive txts, cant send.
10-01-2024 09:55 PM - edited 10-01-2024 10:31 PM
i had issues with trying to send a photo by mms. starting reading about the APN changes. I did what i thought was the appropriate changes.
MMS proxy 74.49.0.18 to mmscproxy.mobility.ca
it didnt seem to work at all. I decided to switch back APN can still receive but cant send any texts sms at all now? RCS chats are working.
I have done everyone suggested in this thread so far. So what happened that caused me to "break my phone" seeing i could send texts just fine now i cant at all?? I was mid conversation when i couldnt send a photo but could text just fine. After neither work now.
10-02-2024 09:39 AM
ive tried different numbers man thats a simple thing to think of.
10-02-2024 09:38 AM
Have you tried sending texts to different numbers, or is it always to the same number? Could the problem be at the other end?
10-02-2024 09:20 AM
hi @JohnTHQ1
ask PM support agent to refresh your account on the system side
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
10-02-2024 09:17 AM - edited 10-02-2024 09:19 AM
did a "network reset" took out my sim reinserted it. still no difference. still cant send a text message. still can receive and RCS is fine. Yeah i dont have another SIM or another phone. Everything but sending texts work....this sounds kinda like they dont want Ulefones sending texts.
10-02-2024 09:00 AM
The APN settings we are changing would affects only data and MMS. SMS does not need the APN
try to Reset all networks again and see if sms starts working. And try the sim card in another phone
10-02-2024 08:49 AM
i tried both last night. a new APN via the plus button or editing an existing one. this is so frustrating as it worked before i changed the settings. change back still not working.
10-02-2024 08:29 AM
@JohnTHQ1 wrote:Its a Ulefone but why does it matter i just want my texting back 😞
@JohnTHQ1 yes, the brand matters. We see different APN tweaks based on the brands
try two things, update:
MVNO (Mobile virtual network operator)value: 4D4F
and if that does not work, try also to recreate a new APN profile based on what I have above instead of updating the existing one. The net new APN profiles instead of updating existing one is needed for some brand
while you create a new one, try both 4D and 4D4F for MVNO
10-02-2024 06:16 AM
10-02-2024 05:57 AM
maybe switch to an e sim?
10-01-2024 10:32 PM - edited 10-01-2024 10:55 PM
10-01-2024 10:29 PM
@JohnTHQ1 what phone is that? OnePlus?
10-01-2024 10:26 PM
just tried this still, cant send 😞
10-01-2024 10:12 PM
@JohnTHQ1 try clear cache
and try using Google Message app as the default messaging app. If you are using it already, uninstall and reinstall (and of course, backup important text first)
10-01-2024 10:10 PM
tried these exact settings still cant send out sms.
10-01-2024 10:02 PM
@JohnTHQ1 wrote:i had issues with trying to send a photo by mms. starting reading about the APN changes. I did what i thought was the appropriate changes.
APN settings don't control SMS, but do control MMS. Wrong APN settings also prevent RCS from working if the settings for data are set wrong. Try using a APN type setting of default,mms and see if that works.
10-01-2024 10:02 PM
what phone do you have?
Compare the APN settings below, try to update it and save:
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
(might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
