03-27-2025 09:46 PM
A friend can't call out or receive calls. Can text though. Has an old Samsung A8. He thinks it has been like this a couple of days. Anyone else experiencing this?
03-27-2025 11:49 PM
We are out in the woods in northern Alberta Canada. We are checking with support to see if there is a solution.Thanks!
03-27-2025 11:46 PM
I think it is a Canadian phone. He is checking with support to see if they can help
03-27-2025 11:45 PM
Thanks. He tried support agent in the app but don't think he heard back.
03-27-2025 10:46 PM
Your friend should send message to a customer agent for assistance:
03-27-2025 09:50 PM
A8, did you buy in Canada?
A8 should have both bands needed for voice on 3G even thought it cannot use VoLTE
Try your phone in different area, hopefully just a local network problem
And Reset network settings
03-27-2025 09:48 PM
hi @AVTIE
what city you are at?
Yes, Telus is refarming all of their 850 to 10 MHz LTE B5 in their markets, mainly BC, AB, Windsor, Ottawa, Montreal, Quebec City. Bell has not done this, so it won't affect area that has Bell networks which Telus/PM use
So, it might affect voice calls for phones that has only 850 Band 5 on the phone but lack 1900 Mhz, those phone people bought in other country. If you phone has 1900 Mhz, if your phone are those that sold in Canada, it likely won't impact you, you won't see any service degrade
https://www.publicmobile.ca/en/get-help/articles/850-turndown
