Calls and texts not working after transfer
MooseMoose
Hey, I transferred my number from Bell to Public Mobile yesterday evening around like 8pm, and I still currently can't receive phone calls and send or receive texts. I'm able to make phone calls however, but when someone tries to call me they get sent directly to my voicemail. I've tried restarting my phone, resetting my network settings, nothing works. I'm using an eSim.
8 REPLIES 8
Michael72737171
I would be so grateful to have this phone number as well. My porting has not completed and I’m desperate. Would you please share the phone number?
Moved:
CSAs aren't supposed to be prompting customers for account information in the message forum.
MooseMoose
Hey, do we have any updates here? I currently do not have any service.
CSA_PM
Customer Support Agent
We appreciate your escalation. An agent is already assisting the customer and will ensure they receive the support they need.
Did you delete your PM eSIM? When you add Bell eSIM, you just need to disable PM eSIM
Go back and check the sim manager sfeand check if PM eSIM is there, you are good, just need to enable it
If it is not there, you are in a bit of trouble, ask PM to help.   Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
MooseMoose
I just called them, they said the porting was cancelled, but I did respond YES to the porting text right away. They added my Bell eSim back and asked me to try again. I tried porting it again and now this time on the public mobile app it says "Your eSim could not be installed. Please contact support."
slusagm
You cannot receive calls because port was not done.  Send text does not work because it cannot activate as port is not done, it will starts working after port is completed
there is a porting assistance team you can call and ask for update. I can't post the number here, but I will message the number to your community inbox. Please check and call them
Dunkman
@MooseMoose
Did you respond "yes" to Bell's confirmation port request text?  Is your Bell service still working?  It might be an incomplete port.
