Re: SIM card not working
Deanster
The link appears to be a bad gateway. Does anyone have the correct link?
The Telus network is very weak where I am.
Yet, I can't change providers.
Please help.
Thanks in advance
2 REPLIES 2
hairbag1
@Deanster
start from the beginning...what are you trying to do ? Are you trying to activate a new Public Mobile account or are you wanting to transfer to a new provider ? More info would help.
Sansan
It's not clear what your request is?? If you need a new eSIM,  just download the app and purchase it. Or buy a new card from a Telus instore. Once your account is active,  you can port out.
