06-19-2024 09:28 AM
Does PM offer roaming in puerto rico and Carribean. Going in a Carribean cruise in August.
10-02-2024 09:47 AM
10-02-2024 09:35 AM
Yes it worked.
10-02-2024 09:15 AM
@MatengHi there...perhaps you could shed light as to if Public Mobile worked in Puerto Rico and maybe the US Virgin Islands? Information from the agents are in consistent. Thanks for your response!
06-19-2024 10:44 AM
as for the rest of the Carribbean area, PM will not work as you stated.
06-19-2024 10:41 AM
Thank you for correction. I will change my post
06-19-2024 10:30 AM - edited 06-19-2024 10:35 AM
@Meow wrote:NO. Only USA/Canada.
PR is a US controlled territory, essentially a state. They have AT&T, T-Mobile and Verizon service there. If the OP has a US & Cdn plan OR a 15 Day US Roaming add-on...it should work as expected.
clipped from Help Files...
Below are some important things you should know about U.S. Roaming add-ons:
06-19-2024 10:15 AM - edited 06-19-2024 10:43 AM
As per below post by @hairbag1 you should have service there. My mistake.
'Unincorporated territory of the United States' whatever that means...
06-19-2024 09:33 AM
Only roaming in the United States. Not in the Carribean, but should have service in Puerto Rico if you have the Canada-US plan or purchase a 15 day US roaming package.
