10-02-2024 09:01 AM
Hi!
I no longer am a public mobile customer, I have switched to Rogers. Please cancel my account (deactive my subscription) and remove the credit card on file. Please do this ASAP.
10-02-2024 09:08 AM
your account is already closed after porting
if you want to confirm, please message support here
10-02-2024 09:06 AM
Hi, your account is automatically deactivated with the change of provider. You can contact a agent by private message to have your credit card removed.
10-02-2024 09:05 AM
@cparsons2017 Did you port out your existing number? If so, your PM account should have automatically closed but still not a bad idea to have a CS agent remove your credit card info on file. You will need to open a ticket through the Chatbot to engage with a CS agent, we are only customers on this community forum:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
10-02-2024 09:03 AM
@cparsons2017 If you ported your number to Rogers your PM account will have automatically closed. To remove your credit card you need to contact customer service. If you can't open a ticket at the chat icon bottom right of this page then send a private message to support using this link
