Best budget plan??
Anas7
Hey I was wondering what the best budget plan is for 3 kids. at the moment they all have 250 mb of mobile data, is there any family plans available or a way to get more data without paying a lot more?
KZ1964
Also there are no family plans with Public Mobile.  If you have 3 kids that you want you have to use3 different accounts with 3 different emails.
hairbag1
@Anas7
Telus has a plan that might be up your alley...they have a plan for new activation that costs $100 for 365 days of unlimited talk/text and 2GB's data monthly if you use the promo code BONUS100. That works out to about $8.35 per month.  I just don't know what happens after the 365 days is up...but in worse case, you could start new PM accounts just before 365 days.
https://www.telus.com/en/mobility/prepaid/plans
cellphoneuser1
Only you know what is the best plan. How much data will the 3 kids use?  How much is the need price point? More data costs more and it won't be free.  Look into plans that cost $29 to $35 per plan if quite a bit more is needed.
HI @Anas7
no family plan here.
I would assume you are shopping for new activation plan, so, $19  plan is the lowest plan you can activate
(unless you are in Quebec, they still have $15, but for Quebec residents only)
