Add on 1GB for US & Canada
valsaphilip
I took a Data & Add on for 1GB (8.5 GB at 3G speed) for my short trip to US. Unfortunately,
my phone never worked in the US during my 6 days visit. Kindly arrange the refund to my account as it never worked and due to this service failure, I had to buy a new GPS.
There was no message and totally I was in trouble during my stay in US.
Regards
Valsa Philip
11 REPLIES 11
wingin
Did you turn on Roaming on your phone?
I had the $60 plan which has US data included and It worked perfectly.
@Lorca wrote:
@valsaphilip I don't think Public Mobile gives refunds.
You're right about no refunds unless it's their fault. They might decide to make exceptions to keep member happy.
Lorca
Triguy
US roaming add-ons expire 10 days after purchase.  When you log into your account under data and add-ons does it appear ?  When purchasing add-ons your need to purchase and then add it to your accont.
https://www.publicmobile.ca/en/bc/get-help/articles/us-roaming
@kerago wrote:
Hi,
I think the add on never expire so even if you don't get a refund you can always use it on your next trip. Good luck!
U.S. Roaming data add-ons do expire even if you never end up using it.
kerago
Hi,
cellphoneuser1
Which add on did you buy? Was it $20 or was it $30 for the 1GB?
hairbag1
Regards
Valsa Philip
The only thing close to what you say is the $50 plan with 8GB + 500MB of data ..it has calling to Canada and US but will only work while you're in Canada. Is this the plan you're refrring to ?
@totalUser wrote:
I can't see 1g add-on for both Canada and usa
There aren't any add-ons that work in both countries. There are seperate data add-ons for each country.
hairbag1
Regards
Valsa Philip
Log into My Account...does your Available Funds show the $$ still sitting there ? If so, you didn't actually "buy" the add-on at all.
PS...which add-on did you buy ? The only one PM offers is the 10 day US Roaming add-ons or the $60 plan.
totalUser
Hi
If you didn't use any of that data you should contact moderators
If you still have it listed please take the screenshot that no data was used
Now are you taking about 60 plan?
