US roaming
Options
01-09-2025 11:28 PM
Hey I live in Canada and am visiting los angles for a few days
When I landed public mobile sent me a message to get US data roaming add on
i bought it with 3gb of data nothings happening
Thanks in advance
Labels:
Service
1 REPLY 1
Options
01-09-2025 11:29 PM - edited 01-09-2025 11:31 PM
If you have a Canada / US plan you can ignore that message...it's sent to all PM'ers when they get to USA. If you bought the add-on, make sure to enabled Roaming Data in your cellphone settings.
