05-13-2023
01:05 PM
05-13-2023
03:55 PM
computergeek541
Hello
I've been trying to activate my sim card...purchased two different sim card and still didn't work.
Tried turning on and off
Did not work.
Rebooted
Did not work
Mark the phone stolen and reactivated.
Did not work.
Meanwhile, my virgin sim card is working right off the gate so clearly its not the sim card issue.
I think that there is some issue with activating new sim card and connecting to Public Mobile network (Telus)...
Can you please help.
05-13-2023 02:28 PM
I will private message you the number to help with porting.
To check your private messages, look at the envelope icon between your avatar and the bell icon on the upper right.
05-13-2023 02:21 PM
hi @randomproblems0 can you login My Account? does it show account status active?
if you have a phone that working on Virgin, the same phone should work on PM network, try your PM sim card there
if it shows now connect, maybe it is really provisioning, just submit a ticket with support
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
05-13-2023 01:25 PM
@randomproblems0 you got 2 sim cards and you activated twice? you paid twice?
not sure why you compare your Virgin sim and conclude not sim card issue. Virgin sim can only activate on Virgin network
let us know what you have done for PM activation, you should have activated once with one sim card
05-13-2023 01:11 PM - edited 05-13-2023 01:12 PM
If you Virgin SIM is still working then porting is incomplete.
You need to leave the Virgin SIM in your phone and wait for the text confirming with YES that your are porting over to PM. There is 90 minutes for you to reply or ELSE porting is incomplete.
Once you confirm, your Virgin SIM will continue to work until porting is completed. Then power off your phone and switch the SIM then power back on your phone.
Easy!
If you missed any of these steps, you need to contact a CS_Agent to restart the porting process for you BUT leave the old SIM in your phone.
05-13-2023 01:07 PM - edited 05-13-2023 01:08 PM
so there's a process to follow if you're porting in to PM from elsewhere. Did you leave old sim in and reply YES within the allotted time ?
added...
https://www.publicmobile.ca/en/bc/get-help/articles/number-transfer-port-troubleshooting
