how do i get support
charlesduo613
how do I get support for lost cell phone, locked out of account
hairbag1
@charlesduo613
obviously, you're gonna need a new phone. Get a new PM sim, then log in to your Account > Profile > Edit account info > Change sim card number.
Slam the new PM sim in the new phone and BAM...you're good to go !
@charlesduo613 try to login to My Account to mark the account Lost/Stolen first
understand you cannot login at the moment, PM support can help
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
Meow
Contact PM agent:
To Contact CSA-agent there are 2 methods:
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Having a ticket is preferred way to contact agent as they might respond faster then receiving personal mail.
If opening a ticket does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+) Here
Agent’s response is usually between 15 and 120 minutes with a ticket. Private messaging might take longer.
Watch for envelope in top right corner of Community page. It will show Number of unread emails.
