01-01-2025 03:20 PM
I opened a Public Mobile account on Monday and transferred my phone number from Bell, but I'm having the following issues:
I have no data service.
I cannot send or receive text messages.
I can make voice calls but only if I use a "1" before the area code, in other words 1-604-xxx-xxxx.
Any hints as to what the problem could be? I've restarted my phone about 6 times, and reset the network settings once.
01-01-2025 04:55 PM
I can receive calls to my number but I can't seem to make calls (I get an automated voice saying there's an error "6UT1", or else I get 3 short beeps and then the line disconnects.
In case this helps I should have mentioned that in my status bar on the phone, there is a 3G that repeatedly appears briefly and then disappears.
01-01-2025 04:47 PM - edited 01-01-2025 04:48 PM
@ddietz wrote:I deleted the eSIM after responding YES to Bell and waiting quite a few hours (more than 5 anyway) and when I logged into my Bell account, it said that my Bell service was cancelled so I assumed that it had gone through.
It looks like porting is done. Can you receive phone calls?
01-01-2025 04:37 PM
01-01-2025 04:22 PM - edited 01-01-2025 04:34 PM
@ddietz wrote:I deleted the Bell eSIM.
Did you do that before respoonding YES to Bell? That means that you will need to contact Bell to get a new eSIM and get your Bell service running again. Only after your Bell service is working again, contact Public Mobile to try porting again. No data isn't a porting problem though, so something else is wrong with your Public Mobile account or your APN settings need to be changed.
01-01-2025 04:15 PM
01-01-2025 04:08 PM
By chance, did you remove your Bell SIM card? Or inactive Bell eSIM?
01-01-2025 03:24 PM
hi @ddietz
entering 1 in front of phone number is normal
for data, what phone do you have?
try Reboot phone and Reset Network settings and see if it helps
i
if same, then submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
01-01-2025 03:23 PM
@ddietz it sounds like an issue likely with your number porting. Did you receive a text message from Bell confirming the port and did you respond "YES" within 90 minutes?
I'll send you a private message with the number for the porting team so that they can confirm for you. Keep an eye on your community inbox (top right corner, icon of an envelope)
