Can't receive code or reset password
QVu
I can't reset password or use public mobile service, not receiving code.
@TheSterlinger wrote:
@QVu hi, click on the link below to send a private message to customer service representative for assistance.
Due to the holiday,  I'm not sure if they are working today.  They normally respond within 30 minutes to  1 hour. Watch the envelope in your inbox for their reply.
There are customer support agents working every day.  The hours are teh same every day including all holidays.
Dunkman
@QVu
There is sometimes an option to received 2FA via email.  Do you see a link "didn't receive code"?
If you don't see the above, then you will need to contact CSA as described earlier.
TheSterlinger
