[Solved] Text Message Issues for Recently Ported Numbers
Ck_PM
Public Mobile
Public Mobile
[Update as of 9:00AM ET 15/05/2024]: A solution for this issue has been successfully implemented last night. Any customer who experienced issues with their SMS service after transferring their number should now have their service fully restored.
Please note that moving forward, customers transferring their number from another provider may need to wait up to 1 hour after the transfer for SMS services to be fully initiated.
Hello Community,
We want to address a current issue some of our customers are experiencing. After porting their phone numbers to Public Mobile, a few customers have reported not receiving text messages. We are actively investigating this issue and working to resolve it as quickly as possible.
Immediate Solution:
If you've recently ported your number to us and are facing issues with receiving or sending texts, please contact a Customer Support Agent directly via our chatbot. Our agents are equipped to apply a fix that should resolve the issue promptly.
We appreciate your patience and understanding as we work through this. Rest assured, we are doing everything we can to ensure a smooth experience for everyone affected. We will keep you updated on our progress.
- The Public Mobile Team
172 REPLIES 172
Tridus
If you go through the support chatbot, it'll ask you to open a ticket. That goes to a person who can fix the issue. I got mine handled in a couple of hours. Click here and then click contact support.
Maisy63
I can’t speak with a person and the robot is useless..we should all cancel and ask for a refund. Almost a month now with no texting
Maisy63
Still unable to send or receive texts..I want a refund..this is ridiculous
MadFerIt
No response from CS after more than half the day, no texting working at all after porting from Fido to public.. Not only that but for the first two hours I had no calling or data as though they never assigned me a temporary number.
I understand part of the low cost is reduced CS but it is completely unacceptable to offer nearly zero support during initial activation and porting for new customers.
Having basic features of a cellular network fail to work where no one is able to reach me, and a CS I need to open a ticket with on a forum where I need to pray they get back to me quickly (they haven't) is atrocious.
mattdexx
I had the same issue and got frustrated so signed a retention plan my old provider Fido offered me. Problem is I couldn't port my number back to Fido because I couldn't receive a confirmation SMS from Public Mobile! Had to contact a Public Mobile CS rep and waited another day to get a reply.
Suchir
I faced the same issue.
Opened a ticket just now, but then found out a solution myself.
Issue is that in Android, if you have S23 model, check in SMS App : Messages Settings => Advanced -> Phone number. (You have to scroll down, it is just before SMSC which is not editable). My phone number was showing Unknown due to the way PM set up the profile. Once I entered my number and did a test, I can then send and receive messages.
I just hope it stays that way and they don't muck it with the ticket I opened before discovering this fix. Good luck everything, this whole Online only customer service is not fun.
fixin1
@couturepoulinj - Since you ordered another one on a eSIM account you shouldn't get charged. If you see $5 deducted from your funds or in your bank account please contact CS_Agent:
Submit a ticket via Chatbot:
⬇️  Click the link for an Agent * ⬇️
* - CS_Agent will typically get back to you within 48 hours. They work 7 days a week from 9 AM to 10 PM EST.  You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you because they may notify you asking for some information via Private Message, in your community mailbox by clicking this link here: Mailbox
couturepoulinj
I transferred and am experiencing the same SMS problem 😞
Transfer from Fido to Public Mobile
I deleted the eSIM and had to buy a new one to "install it again". It didn't change anything. I'm waiting to hear from Customer Support and really want this to work quickly. Do you think Public Mobile will add a discount on my next invoice to compensate for the 2nd eSIM since I just subscribed and tried to resolve the situation without any success?
asls
Finally fixed by getting a new esim. Thank you to the support that helped. But this never should have happened
asls
Seems like I'm the only one who can't get this fixed.
Customer Support have refreshed the network. I have confirmed a second port with my old provider. I have switched all settings, resets, etc.
Still.doesn't.work. Total disaster.
RobR123
My text messages and FaceTime issues are now resolved with help from CS Agent.
Pavitar
Text message issue resolved appropriately via customer support !!
Backira2024
Did you port your number from another provider to public and because of the issue with the text messages you want to go elsewhere? Did you message an agent on line or follow @fixin1 suggestions below? Which provider you did decide to go with? Thanks.
Backira2024
Did you try to contact the agents? I port my number on Sunday night couldn't text or receive texts. I was really angry followed up with agents which they refresh their network, reboot my phone and all set...In less than 24 hours. I was about to port elsewhere like most of us. But trust me options are zero.
Backira2024
@hTideGnow mine was fixed in less than 24 hours. I had public mobile back in the days and I wasn't experiencing any issues. I just hoped as it telus affiliate they had a sort of phone number in case of technical support and not this texting in CS agent type of. Because there are older generations that don't know how to use the service.
hi @Backira2024
only new activation has the problem.  but that is a quick fix anyway, just need to open ticket with PM support agent
Backira2024
My issue has been fixed. I have folks that want to join PM because they are fed up of paying 50+ or some 90+ bills and wandering how is the service? I believe if you buy a new number it's not an issue only the porting is the issue? Do we know when this will be fixed permanently? Or why we as a customers are not receiving emails from public regarding the glitches with the SMS? Thanks
Jack16
En général on répond dans la même journée, car pour moi a quelques reprises j'ai jamais attendu longtemps, je sais quand je reçois un message quand j'ai reçu en email a ma boîte de courriel, aussitôt je vais dans mon application dans mes messages et le message est là
Jack16
La même chose est arrivé a mon épouse, on a fait l'installation de la esim et rien marchait, et quelqu'un m'a répondu et m'a dit d'aller dans mes paramètres du téléphone iPhones 13 et d'aller choisir la esim, et aussitôt tout était parfait, tout fonctionnait
Jack16
Peux être redémarrer le cellulaire, cela remet tout en place souvent
RickyRich
Recommend someone to public mobile and then nothing but problems.  Makes public mobile look horrible. They can’t txt
fixin1
@Chamil - Please contact CS_Agent:
Chamil
Hello I need to port out my number and my new provider send a request to you. Since I am not getting massages I cant accept it. What should I do
bertyou
The CS agent helped refresh the services. And I Reset the network settings, then it worked. Thanks for your help
Destoy
Having this same problem too. Need it fixed asap since all my 2FA’s come to this number. Sent in a ticket, private message and asked the community. I think it’s bigger than a small portion of people.
bertyou
Yes I also have this problem. Now I could not send and receive messages, but I can call or receive phone calls. In the settings, mobile service, it still shows another phone number, please update it
RobR123
I ported my number on May 4th and I’m not able to send or receive text messages. Please help
Vs95
Hi all,
My texts are finally working now. The CS Agent did a network refresh on their end and then instructed me to do the below:
“complete a refresh on your own, this won't delete any data but will require you to enter WIFI connections and Bluetooth again as they will get deleted from your phone.
 Please do the following:
IPHONE
  • Settings > General > Transfer or Reset> Reset > Reset Network Settings> enter your password or PIN if needed
  • Then wait for the phone to power off/on and do another test of your services.
I will need to highlight that you need to:
Make sure you only have one SIM in the device, having more than one will generate connection problems.”
asls
This is a serious issue. No texting means I cannot undertake two-factor authentication for services like banking or my work VPN login.
Fix this now.
fixin1
I hope @Ck_PM and their team is working on it! I would rather you fix the iMessage activation & SMS / MMS issue before any new features!
We have been getting low quality service for some of these people & most of us are considering porting out right now!
As for you @mesopotamian , if you haven't contacted CS_Agent, please do so:
