01-07-2024 02:38 PM
When I go into my voicemail settings it says that I have my personal greeting activated, but when anyone calls me and reaches my voicemail they still hear the auto-greeting "the person you're trying to reach is not available...".
I tried re-recording my personal greeting but it still isn't working. My husband and mom are both having the same issue with their VM. We all recently changed our plans with public so wondering if this is what caused it. Please help!
01-15-2024 12:33 PM - edited 01-15-2024 12:34 PM
@melmadsen The Apple Live Voicemail, from what I have read, requires the carrier to offer Visual Voicemail, which Public Mobile doesn't, in order to personalize the greeting. Otherwise it gives the standard Apple greeting. PM is not the only carrier where a greeting in Apple Live Voicemail can't be changed. So it's not really a Public Mobile glitch, it's just the way Apple's Live Voicemail works. Live Voicemail is a feature of ios17 as far as I recall, nobody had it before that ios upgrade.
01-15-2024 12:03 PM
That totally bites if it's the visual voicemail that's causing this issue! I actually rely on the visual voicemail while I'm unable to pick up the call, but need to know why the person is calling. to have to remove this because it's affecting my personal voicemail, well that is really a glitch that Public Mobile needs to figure out how to fix!
01-07-2024 03:15 PM
To fix this problem PM would need to add support for visual voicemail. Or Apple would need to add support for custom greetings without it.
01-07-2024 02:44 PM
@Paige4 Do you receive other incoming calls generally, those that aren't sent to voicemail?
01-07-2024 02:40 PM - edited 01-07-2024 02:41 PM
@Paige4 Are you using iPhone ? Try turning off visual voicemail see if that helps
and here some light reading in voicemail set up
https://www.publicmobile.ca/en/ns/get-help/articles/voicemail-faqs
hope this helps
