12-12-2024
10:22 AM
12-12-2024
11:04 AM
computergeek541
I ported my number from Rogers to PM and everything is working. Calls (incoming/outgoing), SMS and Data. My old Rogers account no longer shows my phone number on the account, the SIM doesn't work for calls/texts. My phone number goes to the PM Voicemail.
All and all great.
It has been 12hours but I have yet to receive a text from PM saying the transfer is complete AND iMessage/Facetime isn't working. I tried turning them off and restarting and resetting the networking settings but neither seems to have worked. I wonder if the issue is I haven't received the PM text yet saying it is complete
12-30-2024 04:54 PM
I did. Apple will text you to verify. And add it back in. Make sure to reboot after. Just in case.
12-30-2024 02:30 PM
My number is still currently tagged to my appleID since the transfer. Should I delete my number from my appleID account and add it back in?
12-30-2024 02:26 PM
This morning I did receive phone calls from iPhones and Android phones, but it was lagging. I had PM contact me through the ticket and ask to change my APN settings on my iPhone 14 Pro Max from isp.mb.com to sp.mb.com and now I can't receive any phone calls. I switched the APN Settings back to factory reset for PM and still nothing.
Here is the link they provided for the APN settings https://apn.how/ca/public-mobile/apple-iphone-14-pro-max
12-30-2024 12:47 PM
@coree see below:
12-30-2024 11:49 AM
but can you receive phone calls? did you call the PM porting team to confirm if your port was completed ?
12-30-2024 11:48 AM
Thanks for the detailed steps, unfortunately the iPhone 14 is not yet back to its normal state, but I do get iMessages using my emails addresses but not the phone number. I cannot send messages to people who have android phones and says it’s not delivered, but I can receive text and text notifications from Eversafe confirmation codes for my PM account through my number.
I’ve attached 2 screenshots, the text notifications from Rogers that I got. Was it the only 2 that you get? I will be contacting them today as well to see if it’s been fully transferred on their end, I’m sure it was. Also it hasn’t been 24 hours yet so I guess I’ll be patient.
12-29-2024 09:12 PM
Hi @coree couple of things.
Hope this helps.
12-29-2024 07:40 PM
I am having the same issue where I have a rogers sim card and purchased an esim. Got a msg from PM saying "to successfully complete your number transfer request, please restart your phone. Welcome to Public Mobile and thank you for joining us!" I did restart but my PM cellular does not have my current number displayed, should I not see this on an esim? Texting and calling to an Android phone doesn't work. Facetime and iMessage only works from my email addresses and not my number. @MattGruden did you get this to work from an esim or sim card yet?
12-27-2024 08:38 AM
@MattGruden I'm having the same issue with my wife's phone. Did you get this to work? If so what did you do? Tks.
12-12-2024 10:26 AM
@MattGruden try turning off face time and iMessage and go to phone settings > general “shut down”
wait 2-3 mins and turn phone back on and then go turn on face time and iMessage and test again
12-12-2024 10:26 AM
hi @MattGruden
first , remove the Rogers sim card (or disable if it is an esim), then reboot your phone with the PM sim card and check if you can receive inbound calls
if inbound calls work, then the port is completed
for iMessage/Facetime, go to the settings, remove the phone number, reboot phone again and go back to the iMessage settings and enter the phone number again to reregister
