my number doesnt work
Jasmeetkaur
i recently switchecd to public and my new mobile number doesn't work. it shows i have two different numbers and idk.
hi @Jasmeetkaur
remove your old sim card if it is physical
disable your old eSIM if it is an eSIM
then reboot phone and Reset All Networks on the phone
is same, message support for help
Dunkman
@Jasmeetkaur
More information would be helpful.
Are you able to receive calls or texts on your original phone number?  What about outing calls and texts?  Data working?
@Jasmeetkaur  Try rebooting the phone first if you haven’t already or reset network settings see if that helps
