I cannot make calls or receive calls but data is working
Bagera
Hi,
I have 2 sim cards in 2 different phones from public mobile, I cannot make calls on both phones but data is working any insight?
17 REPLIES 17
Bagera
I have 2 phones 1 supports volte and one does not and both does not work even though the one with volte is enabled. Yea 3G is not working at all. Only data on 4g and 5g
the fact that it does not connect to 3G means there is a 3G network problem in your area.  Your phone is not VoLTE compatible with PM, and therefore you are not getting voice
open ticket with PM first
at the same time, check if your phone has a VoLTE toggle.  Maybe on the Connection screen.  Enable it and test calls again
Bagera
It does not connect to 3g however it does to 4g and 5g and I have data but no talk.
My account is valid and not suspended
but can you confirm if the phone connects to 3G? or not able to connect to any network?
if it does not connect to any network, then it is the account (maybe suspended) or a network problem.
to confirm if account problem, please login My Account and check if it is active.  if it is a network problem, please send PM a ticket
Bagera
Neither 3g or 4g or 5g works non.
when you set the phone to 3G , does it connect? if not, it shows there is a problem with the 3G network in the area
Bagera
Same thing does not work
reboot the phone first
and also change the network mode to 3G (some phones call it WCDMA or HSPA)  and check if you can use voice calls on the 3G network
PM has removed the mobile data/voice outage alert in Calgary, so it should be fixed.  Try reboot the phone
https://www.telus.com/en/ab/outages
or if you still encounter the same, tell PM your service problem.   Just open ticket with PM using the Orange Chatbot icon on the lower right. Type the question Submit ticket and select Contact Us to get to ticket open screen
or message them using this link:
Bagera
I tried a Samsung instead of a xiaomi and it worked seems like Public mobile is blocking xiaomi / redmi or some brands
Soni10
I'm in Calgary and have been unable to make or receive calls since this evening.
Bagera
Any reply .?
Amber-26
I’m having exactly same issue this evening. And I have RedMi.
I just sent private messages to PM agent, here is the link,
Bagera
I'm in Calgary
are you in calgary?  Calgary has some reported issue
but try Reset network settings
Bagera
Both phones are xiaomi and both was working fine yesterday
slusagm
could be 3G problem in your area and your phone not a VoLTE phone whitelisted by PM
so, what phone do you have?
