12-19-2025 12:59 PM
I am unable to send sms messages but I can receive. I have an iPhone and iMessages are fine.
12-19-2025 05:10 PM
On the newer iPhones, you can enable RCS Messaging in Settings>Messages>enable RCS Messaging so you can use both iMessage and RCS.
12-19-2025 01:06 PM
first reboot phone, then Reset network settings and going make sure send text is enabled on the settings
and try send to different people, sometimes it is the receiving end
and when the text shows not sent, press and hold to bring up the menu and click Send as SMS
12-19-2025 01:00 PM
@mjburge Calling and data work ? Can try resetting network settings see if that helps
12-19-2025 01:00 PM
a network reset may cure this...give it a try.
