12-19-2025 05:29 PM
I just bought a new iPhone but it is eSIM only
how can I upgrade my account with an eSIM but keep my phone number and my plan?
12-19-2025 05:54 PM - last edited a week ago
Sim cards are one time use. A previously activated sim card cannot be reused.
If you are planning to activate a new account , but a sim card first from
12-19-2025 05:49 PM
thanks. Can I reuse the current sim card to activate another account? I am waiting for the Boxing day deal and bring in a line
12-19-2025 05:32 PM
no worries, you can easily change to an eSIM and keep your phone number and account. Many community members upgraded to eSIM only iPhone and are doing the same
To buy eSIM for your new phone, download the PM app on your new iPhone and login. It will send you a 2FA via text and you should be able to receive that on your old phone with the physical sim. Just in case, you have problem with receiving 2FA code, click "Didn't Receive code" or "Resend code" and choose either Send email or Send voice message
After logged in, Click Account > Purchase sim card> eSIM.
Once it confirms your phone is eSIM compatible, click Pay $ and Install and follow the steps to install the eSIM
