unable to make an international call to australia even with the 300 minute addon
leekwen
the response i get is "we're sorry your call could not be completed as dialed"
The number is correct (it even shows up with caller ID).
8 REPLIES 8
@darlicious wrote:
Edit:
As per @computergeek541's post drop the "7" after +61.
not necessarily drop the 7 but rather replace it with whichever number is valid in its place for that specific phone number
@leekwen
need to drop the  0
if the number is like that  (61)  02 9211 2233., you call as 011 61 2 9211 2233
@VIP_Tech wrote:
Hi @leekwen
try
011617xxxx xxxx
The country code for Australia is 61 (not 617).  There are many numbers in Australia that use a different number after the country code.  I would also suggest using +61 instead for the sake of simplicity.
From my experience, calls from Austrrlia sometimes show as the number coming from 161xxxxxxxxxxxxxxxxxx.  That will cause problems if you're redialing form the call history as the format is incorrect.
darlicious
@leekwen
Are you trying to call a toll free number? In particular a government one? Toll free numbers cannot be accessed even with a long distance add on as they are refused by the destination end due to the expensive rates charged for international callers to Australian toll free number account holders. You will have to Google a local access number rather than the toll free number in order to call that business or agency.
Or if you are not dialing correctly then just use @VIP_Tech 's advice.
Edit:
@leekwen are you sure the recipient is able to accept international calls?
For calls from Canada to Australia dial: 011 + 61 + area code + telephone number.
Dunkman
@leekwen
Is your Canada calling working? text? data?
Is it just one Australian number that you can't call?
What about other Australian numbers?
Do you see the long distance add on in your self service account?
VIP_Tech
Hi @leekwen
try
011617xxxx xxxx
Edit: @computergeek541
the 7 is not country code
How to call Australia from Canada
