International minutes to pakistan and India
Kasif
how you find that your eligible for 1000 international minutes and how much you used.
@Chalupa_Batman  If you feel you can use 750 minutes then you can pay $15 extra per month
You'd have to use up all 750 minutes to have to pay $15 month since the LD minutes don't expire in 30 days like the data add ons do.  They stay on the account until they are used up, however long that takes. Or am I misunderstanding what you are saying?
Kasif
Ok let me check.
Kasif
Yes  I have a plan it's was showing when I subscribe the plan but not showing whether I have or not?
Chalupa_Batman
I'm working off the first part of your question @Kasif ...  how you find that your eligible...   You have to choose a plan that has 1000 International minutes. Or, you can purchase Addons for International minutes. For example.
750 India & Pakistan Long Distance Minutes - $15 add on.
If you feel you can use 750 minutes then you can pay $15 extra per month. However, if there is a plan that cost a few more dollars than what you have now, it may be worthy to upgrade your plan to one that comes with it.
kb_mv
@Kasif Look on the main screen of the PM app. Select "Usage Breakdown". The next screen shows the LD minutes and how many you have used/ / have left.
