traveling
livva
Hi. I am traveling soon and want to suspend my plan for 70 days? can someone please advice me how I can do it? Where should i go in My account and what to press? Like step by step
9 REPLIES 9
darlicious
@livva
How exciting....where are you going to travel? Here are your options....ignore the rewards advice and note the points program info following the spoiler if that applies to you.
Spoiler
  1. You can turn off autopay and allow the account to suspend at the of your current 30 day cycle but this is your least advantageous option. Pay and reactivate by day 85 or so.
  2. If you have an account balance that exceeds your plan amount then you need to suspend via the lost/stolen feature in your account before midnight eastern on the evening of your renewal. Then on day 85 or so resume your service to pay and reactivate.
  3. Suspending via lost/stolen before midnight eastern will keep your voicemail active allowing you retrieve voicemail and any verification sent by phone calls. However your rewards will not be applied to your account. CSA contact after paying and reactivating is necessary to have the rewards applied manually.
  4. Voicemail can be accessed by calling your pm number from a different phone by calling your phone # and pressing * once connected and entering your 4 digit voicemail pin #.
  5. If you don't have an account balance or enough balance to cover your plan amount you can suspend via lost/stolen after midnight but before 2 am eastern on the day of your renewal. Once your rewards have been applied (usually by 12:15 am et) then suspend your account. Voicemail access will be lost.
  6. Switching to the $15 plan with rewards helping to cover a partial or full amount of your plan allows you to call forward your pm number to your voip number  before you leave Canada.. Now any incoming calling to your pm number will ring thru to your voip number while on wifi or mobile data (w/a local or global sim card) You can access your voip app voicemail for all voicemail messages.
Most important mark on your calendar day 85 of your suspension and day 90. Do not forget when you must unsuspend your account via lost/stolen and/or pay and reactivate your service so you don't lose your phone number and account. Happy travels and Stay--Safe!
Note: Rewards in the spoiler above refer to $$ rewards. Public Points customers supposedly continue to earn points while suspended.....YMMV....until we learn more.
Obviously now that there are two rewards programs I need to update how the points program is affected....which is a little YMMV nowadays because the points program is still new and most of us regular members are on the $$ rewards program. However according to the terms of "Public Points" you continue to earn points even when suspended either via lost/stolen or for non payment.
That works in your favour when suspending for more than 60 days in a row every year. With anniversary points (vs loyalty) you get 10 points on your 1 year anniversary (and on your second you get 10 points and so on....) whereas $$ rewards would delay loyalty rewards by 60+ days....as well the way the terms read for points you also still earn friend referral points and also in theory community rewards if you continue to participate in the community while away....?🤔
Rahulahuja
no it won't show you like this because it will be in a suspension period. when you come back just put the amount of money according to your monthly plan and it will be good to go
Yummy
@livva wrote:
thank you. Im on auto pay now. If i remove auto pay it wont show I owe two months worth of payment when I am back ?? it wont ask me to pay ?
In suspension your phone will not work. No extra charges, no fines, etc.You might delay a little bit loyalty reward but it is insignificant. Just remember to resume your service before 90th day or you will lose account and number.
Rahulahuja
yes, you will be fine for 70 days if you have setup auto -payment
make sure you remove it.
@livva   No worry, it won't    PM is prepaid, you pay before you use the service.  So, you do not owe them anything while you are away.
Just make sure you reactivate no later than 90 days after the first day of your suspension or your account will be closed and you will loss your number
MrSpock
@livva no it won't ask you to pay for those months you just reactivate and pay from the time you get back
livva
dabr
@livva   You can remove any payment card and your account will suspend after no payment for 90 days.  You'll need to make a payment before the end of 90 days if you don't want to lose your number/account though, so  make a payment at least couple of days before 90th day of suspension (although not needed if only suspending for 70 days).
If you have a balance equivalent to your plan payment, then you need to click the Plans/Add-on tab, Lost/Stolen and Suspend service.  Reminder you have to go back and Resume service once you are ready to reactivate your account.  It's always a good idea to reboot after reactivating the account too.
MrSpock
@livva hi 70 days is no problem just remove auto pay and let it go into suspension  simply don't renew plan then you have 90 days to reactivate 😀
