02-13-2025 06:17 PM
I'm going to Japan for two weeks and getting a local SIM card. This is my first time using a SIM card.
My phone is a Galaxy S21 FE (not compatible with eSIM)
Q1. Will my phone work right after just switching the SIM card?
Q2. If my phone needs to change any settings, please tell me how.
Q3. When I come back to Canada and put the original SIM back in, do I need to change any settings?
02-13-2025 10:40 PM
try either Japan Wireless or Sakura Mobile.
02-13-2025 08:39 PM
Hi hairbag1,
Thank you for sharing your son's experience.
I don't know what carrier or phone he used, so I can't be sure it will work the same way, but it's good to know it doesn't seem too difficult.
02-13-2025 08:34 PM
Hi hTdeGnow,
Thank you for your detailed and thoughtful advice. 😀
I will contact the carrier I am considering making sure.
02-13-2025 08:29 PM
Hi, hairbag1
Thank you for your message.
That sounds very simple and easy.😀
02-13-2025 06:58 PM
good question Meow...look at the end of each original question is where I answered the questions. I guess I could of highlighted them...I will do so.
02-13-2025 06:40 PM - edited 02-13-2025 08:01 PM
Removing wrong information
A friendly reminder, there is also no need to have the habit to bravo OP's original posts. Don't see why questions worth any bravos, unless it was intended for another purpose
02-13-2025 06:26 PM - edited 02-13-2025 06:29 PM
my son returned from a trip to Osaka..he removed is PM sim and installed Japanese sim without changing anything. Same when he got home. (Not sure what make of cell he has)
added...make use of WhatsApp to stay in contact with family in Canada. It's free to talk / text with any others who have WhatsApp....for free using wifi or local data.
02-13-2025 06:23 PM
hi @makko1
1. technically yes. But confirm with the Japanese network carrier that your phone is compatible. You might need to give them the actual model number, not just S21FE
2. If any setting change, it will be a question to that local sim carrier. But generally, make sure the Public Mobiel sim card is removed, and you can Reset network settings after you insert the new local sim
3. Make sure you only Public Mobile sim card is in the phone. Check VPN settings page, some local sims use VPN , you need to delete those VPN settings. Again, you can then Reset Network Settings when you are back
02-13-2025 06:22 PM - edited 02-13-2025 07:00 PM
@makko1 wrote:I'm going to Japan for two weeks and getting a local SIM card. This is my first time using a SIM card.
Q1. Will my phone work right after just switching the SIM card? ...remove PM sim and install Japan sim should work just fine.
Q2. If my phone needs to change any settings, please tell me how. ...shouldn't need to change a thing..as long as you can read Japanese !
Q3. When I come back to Canada and put the original SIM back in, do I need to change any settings?...nope. Remove Japanese sim and install PM sim. Make sure your account is active and you should be good to go.
ed...good suggestion Meow.
