Plan change
mariak881
I need to change a plan
@mariak881
PM is an online service and you have control of your account.
Login to your account and click on Change Plan with option to change now or on your renewal date.
Since PM is a prepaid service, you have paid for 30 days of service so there will not be a refund for unused days.
If your renewal plan is long time away, meanwhile you can purchase additional data.
dust2dust
You can do it yourself in the self-serve. Be sure to select at next renewal as there's no pro-rating here.
JK8
@mariak881
You can do this in self service. You have the option to change plans immediately or change on the next renewal date. If you choose immediately you will not get any credit for the time remaining on your current plan.
