02-13-2025 01:00 PM
02-13-2025 01:06 PM
no roaming in India. PM only has roaming in US and Mexico
use local sim card or travel esim instead
02-13-2025 01:05 PM
@Deepak79 Public Mobile does not have roaming in India, it's only available for US and Mexico. Your options would be using Wifi or getting a travel eSIM or a local SIM for the region you will be travel to
