07-01-2022 12:41 PM - last edited on 07-01-2022 06:04 PM by computergeek541
07-12-2022 07:36 AM - last edited 4 hours ago
https://www.gsma.com/coverage/#466
The Coverage map. Can also lookup coverage for other carriers in other countries as well
07-05-2022 11:13 AM
what phone do u have?
07-01-2022 01:37 PM
Lol...wouldnt I like to know.....took the pic, copied the link and my stupid tablet reboots and for the life of me I can't find it again! Oh wait a sec....found it!
07-01-2022 01:30 PM
HI @darlicious What site is that?
07-01-2022 01:28 PM
3G network coverage is extremely limited in Alaska. Here is where you can try to get service.
07-01-2022 01:13 PM
Thank you
I will try again in Anchorage tonight
07-01-2022 01:11 PM
Fortunatily I go to Anchorage today
Thanks. Will do it there
07-01-2022 01:11 PM - edited 07-01-2022 01:12 PM
@darlicious Roaming as in T-Mobile users have to pay? or use it for free?
Can PM users tap onto ACS and CGi then?
07-01-2022 01:10 PM - edited 07-01-2022 01:22 PM
@Igorreentov It's good that you see AT&T network
Do you have Data in your Roaming purchase or just voice? If it is voice, AT&T has started shutting down 3G (which voice in PM needs) so they might not have 3G in that area. Data uses LTE and it will start work if you can connect to the AT&T network
07-01-2022 01:08 PM
US talks
07-01-2022 01:07 PM
I'm in Fairbanks and manually switched to AT&T
Doesn't help
07-01-2022 01:07 PM
T-Mobile service in Alaska is roaming on either ACS or CGI.
07-01-2022 01:02 PM
HI @Igorreentov if you still unable to use the roaming but have Wifi around, download VoIP app like TextNow and Fongo to make calls for now
If in the end, you cannot use it at all, open a ticket with PM and they will cancel the add-on and put the money back to your account
07-01-2022 12:57 PM
@darlicious you see there is a Heart in the T-Mobile coverage map in Alaska? LoL
A very romantic provider
07-01-2022 12:55 PM
HI @Igorreentov are you going to be there long or just a day here and there from cruise?
Find a T-Mobile or AT&T store and ask for help.
07-01-2022 12:54 PM
Lol....I just realized my reference was from 2019!😀
07-01-2022 12:52 PM - edited 07-01-2022 12:58 PM
@darlicious T-mobile does have some coverage
With the recent complains about coverage in Alaska, I wonder if they had more 3G area for both AT&T and T-Mobile. Now with 3G shutdown, they left with very minimal coverage in that state
07-01-2022 12:48 PM
Your only option is At&t. It is unlikely voice services will work. Which US Roaming add on do you have?
T-Mobile has no network in Alaska.
07-01-2022 12:48 PM
HI @Igorreentov you sure you completed both steps:
A: Purchasing Add-Ons is a 2-step process:
You will need to add funds equal to the amount of the Add-On to your account.
Then, click on ‘Purchase Add-Ons’ on the Overview page.
07-01-2022 12:44 PM
@Igorreentov there have been many complains about roaming problem in Alaska lately.
which city are you now at?
Try to manually change your network to AT&T and T-Mobile (see if you see it on the list). You have to pick one of them to get the roaming service
