Data roaming is not working
smanikav
Hi,
I have just signed up for Canada- US 50Gig plan and my roming data is not working in US.  How can I get this resolved?
Sutharshan
smanikav
Hi @hTideGnow,
Thank  you so much and it is now working.
Cheers,
Sutha
DennyCrane
You're probably connected to AT&T 5G, which doesn't work for us. I personally prefer to leave my Network Selection to AUTOMATIC and change my PREFERRED NETWORK to 4G/LTE to avoid connecting to AT&T 5G. But you can also manually connect to T-Mobile if you like.
Chalupa_Batman
Hey @smanikav
Go into your network settings. Choose T-Mobile as that works best. Then also make sure your data roaming is turned on. Then reboot the phone. If you don't know how to do this, let me know if you have an Android or iPhone.
@smanikav
Critical part to US roaming depends on T-Mobile/AT&T coverage and whether you can connect successfully onto either network.
If the phone is not connecting to T-Mobile/AT&T, change the Network Connection from Automatic to Manual and select and test both T-Mobile and AT&T and see which one you can connect.
If your issue is with data, make sure your Roaming Mobile data is enabled and you have disabled your mobile data limiter.  Also change your network mode to 4G (and don't try 5G until you can connect and works on 4G)
If your issue is with voice, make sure VoLTE is enabled on the device setting.  And if it does not work, try to change the Network to T-Mobile ONLY, and change  Preferred Network Type or Network Mode to 2G and see if the calls go through.
Also, you can download VoIP app TextNow as a workaround to make calls and text if you have Wifi or if your roaming has data component and data  is working
HI @smanikav
make sure you are connected to T-Mobile or AT&T.  Use manual connection if needed.  Try both and see which one work
Don't use 5G, change it back to 4G
and of course, you need to enable Mobile roaming data on your phone for it to work
