3 weeks ago
- last edited
3 weeks ago
computergeek541
Do I need to have my roming option switched to on when I go to the USA from canada. Or does it change automatically when I cross over With roming switched off on my phone.
3 weeks ago
Of course. You're still roaming on another carriers network, even if it's included in your rate plan. Because it's a prepaid carrier it's better to leave data roaming on all the time, as there will never be any extra charges.
3 weeks ago
Yes, you have to turn on Data Roaming. it does not change automatically if data roaming is switched off.
Suggestion-
this is prepaid company. you will not get extra bill if you turn on Data roaming. it should be ON all the times so that you do not have to do it Manually.
steps to turn on Data roaming
1. go to Settings of your phone
2. go to Cellular
3. go to cellular data options
4. turn on Data roaming
and then you are good to go.
in case if you are not getting network once you are in USA then you can try to follow some instructions.
2. go to Cellular
3. Network selection
4. turn off Automatic
then it will show you some USA carriers and try to select one by one then you will get networks if public mobile has tie-up in that area with USA carriers.
3 weeks ago
additional info...actually you can enable roaming as directed and just leave it on. With Public Mobile you pay for your plan and when you reach your data limit...it just stops. You'll never be billed for extra data usage or anything else with pre-paid service.
3 weeks ago
Hi @Bueckert ,
As mentioned you have to enable the roaming while traveling to US, here is the link to read about it and how to enable it:
https://www.publicmobile.ca/en/ab/get-help/articles/us-roaming-troubleshooting
Best.
Hope that helps.
3 weeks ago - last edited 3 weeks ago
go to settings and enable Roaming Data to use data while in US with the Canada / US / Mx plan.
