11-25-2019 12:46 PM - edited 01-05-2022 08:08 AM
11-25-2019 02:59 PM
@breanna1928The long distance message is a catch all error message. If the account is out of minutes it will sound the same message, so it is important to log into the selfserve account ot make sure there are outgoing minutes left. (Checking voicemail also count as outgoing minutes so beware)
11-25-2019 02:47 PM - edited 11-25-2019 02:50 PM
@breanna1928 wrote:he can only receive calls, he has restarted his cellphone and not working still, gives him an automated msg that says "sorry you cannot make long distance calls upgrade your plan" something like that but he isnt calling long distance.
Just to clarify, he does still have minutes left on his plan ($15 plan has 100 outgoing mins)? If he's out of minutes then he should purchase the $5/500 Canada wide minutes, these will not expire and will roll over every month until used up and are a great supplement for limited plan minutes.
11-25-2019 02:44 PM
@breanna1928 wrote:he has the 15$ plan
Has he tried adding +1 in front of the his calls as suggested earlier?
11-25-2019 02:43 PM
11-25-2019 02:42 PM
he has the 15$ plan
11-25-2019 02:07 PM
Sometimes these warnings are frivolous and the call goes through anyway.
11-25-2019 12:55 PM
Does the phone that you are having issues with have a dual SIM card slot ? Try removing the SIM card and put it into the other SIM card slot. Had the same issue with my phone.
11-25-2019 12:52 PM
Make sure to include the area code. What plan does your husband have ?
11-25-2019 12:52 PM
@breanna1928 try restarting the phone. Then you can try adding 1abd the area code in front of the number. Can the phone receive calls just to rule out account problems
