my account
squash1961
i can't sign in
Yummy
Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
@squash1961
what exactly was the issue?  did you even get to the 2FA screen?
if not,  you can first try to Forgot email link  ( https://eversafe.id.telus.com/user/forgotemail?locale=en&ForceAuth=true  ) and then Forgot password link  ( https://eversafe.id.telus.com/user/forgotpassword?locale=en&ForceAuth=true ) on the login page there. They will send you the "hints" to the correct email address associated
If that does not help, please open ticket with PM support
@squash1961  Try tapping resend code a few time to see if you get option to send code to email instead . If stil no luck . Submit ticket with support to help you regain access to it
message support directly
while your already here and logged in the community you can send a private message   To CS_Agents click
