Having some issues porting a number from Fido
Nith
Hello,
I ported two lines from Fido this evening. Both physical sims to esims. The Samsung device ported seamlessly, but now I’m having issues with the iPhone.
I received a welcome message to restart the device and loss my Fido service. After rebooting, I see the device is now on Public Mobile, but there’s no technology icon (3G/LTE/5G). I cannot make outgoing/incoming texts, no data, no outgoing calls but weirdly incoming calls works and shows up as Unknown.
I’m just wondering if the porting is still ongoing and it’s a matter of being patient or is there an issue that needs to be addressed? It’s been about 5 hours.
Please note that when I log into my Fido account, both lines are ported out and the account has been automatically cancelled.
Thanks.
Nith
I didn’t expect a reply but CSA reached out. They did something on their end, asked me to power cycle my device, and now everything is working. Thanks.
Nith
Hello, thanks for the response.
Yes, I removed the physical sim and tried restarting the network settings but still the same issue. I will submit a ticket. Thanks again.
Dunkman
@Nith
Porting should be done by now.  Maybe try a network reset of the phone. Note this will erase any saved Wifi password, etc. Did you remove the Fido physical SIM card from your phone?
If that does not work, you likely will need to contact customer service agent for more troubleshooting.
Send a ticket via the chatbot to customer service agent (CSA) via link:
Send a private message to CSA through the following link :
Most CSAs are not working now, so you may need to wait until morning for response.
