11-27-2024
09:34 AM
11-27-2024
10:09 AM
Dunkman
Reactivated my line with a new plan but was assigned a new cell 437-xxx-xxxx. My old number 416-xxx-xxxx was assigned to my account from Telus. How do I get the old 416-xxx-xxxx back ?
11-27-2024 12:42 PM
thank you
11-27-2024 11:46 AM
hi @Johnnyboy66
we are just customers and we cannot confirm. But if your account already suspended for 90 days, then the number will be gone and PM can reuse the number for other accounts
I mentioned earlier, best to contact support agent and they can tell if the can do anything. Have you opened ticket yet?
11-27-2024 11:15 AM
@Johnnyboy66 You need to contact customer service as explained earlier in the thread, there are no Public Mobile employees here in the forum, it's just customers like you trying to help.
11-27-2024 11:14 AM
@Johnnyboy66 We are just customers like you trying to help , we don’t work for public mobile .and we sent you the info on how to engage support read thru the reply’s . The number on account was closed it would go back to the carrier the number originally came from . But in your account profile page you can scroll thru the number pool . Note you can also change your number 4x for free every 30 days
Change # on profile tabs
11-27-2024 11:09 AM
please confirm if the number is no longer with PM.
11-27-2024 11:05 AM
same. And once your account was suspended over 90 days, your number is gone and you really cannot control how mobile providers use your number. It will be nice if they can give you back, but if not, then you will have to move on with new number.
Some people actually pay extra or port in and out to other VoIP just to keep the number
11-27-2024 11:04 AM
what does PM do with the number after suspension of 90 days ?
11-27-2024 11:03 AM
It was ported and activated on PM last year. Is your summation still the same ?
11-27-2024 10:53 AM - edited 11-27-2024 10:53 AM
the number is really Telus'
But it could be in the "cool down" stage right before it available in the pool to be chosen again and no one can choose it now
the number could have also be the the VoIP provider now. It wasn't picked yet, but out of Telus hand and with the VoIP
11-27-2024 10:50 AM
11-27-2024 10:50 AM
416-910-78XX
11-27-2024 10:47 AM
the number you want, what is the next 3 digits after 416?
11-27-2024 10:44 AM
11-27-2024 10:43 AM
11-27-2024 10:20 AM
@Johnnyboy66 Well try support then see if they can help you
submit ticket with support using the chat bubble bottom right of screen
If that doesn’t work you can always send direct private message to support .
11-27-2024 10:20 AM - edited 11-27-2024 10:21 AM
Then PM can certainly do it but hard to say if they are willing to assign you the number. These days, they don't like people choosing their number. But since you had that before, maybe they are ok
Just open ticket with PM using the Orange Chatbot icon on the lower right. Type the question Submit ticket and select Contact Us to get to ticket open screen
or message them using this link:
11-27-2024 10:19 AM
11-27-2024 10:18 AM
Telus advised it is with PM.
11-27-2024 10:06 AM
@Johnnyboy66 Yes but if the account was closed due to be suspended more then 90 days , the. The number will go back to the carrier it originally came from so in this case you said it was Telus ? So I think you need to contact Telus even though PM under same umbrella .
11-27-2024 10:04 AM
Called and got a recording 6UT1
11-27-2024 10:03 AM
It was ported to PM last year. It should be with PM. No one newer when I called
11-27-2024 09:41 AM
HI @Johnnyboy66
please remove the phone numbers. We are just customers in this community
so, was the old number still active with Telus or it is not active now with any carrier? If you own the number between with PM, there is a chance you can get it back. Contact support agent and show them some proof you had that before
submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
11-27-2024 09:41 AM - edited 11-27-2024 09:46 AM
@Johnnyboy66 The numbers probably gone , start by calling the number to see if somebody answers it ,if it’s assigned to someone your out of luck but if not then if you got the number from Telus you can try get the number and plan with them to port the number over to to your PM account
