10-19-2021 04:25 PM - edited 01-06-2022 03:34 AM
i have some issues with outgoing texts no working but incoming are ok.i do not know what is going on .i tried many things and no luck. i am in public mobile for 6 month and never have a problem. iam using a motorola moto e and i tried on another phone and not luck. it no logic.plese some body tell me what is the issue? it is a little frustrating
10-20-2021 07:54 AM - last edited on 10-29-2021 04:00 PM by Luddite
I already change my sim card and voilà,everything is working again.anyway thanks for your help.much appreciated
[sometimes a SIM does fail ....... Luddite]
10-19-2021 10:35 PM
Did you recently port a number in?
10-19-2021 10:24 PM
@roberto24 wrote:i have some issues with outgoing texts no working but incoming are ok.i do not know what is going on .i tried many things and no luck. i am in public mobile for 6 month and never have a problem. iam using a motorola moto e and i tried on another phone and not luck. it no logic.plese some body tell me what is the issue? it is a little frustrating
If you do have Chat Features, I would suggest turning them off:
Ensure your 'motorola moto e' is install with the latest software updates.
Reboot your phone after any updates are completed.
10-19-2021 08:50 PM
@darlicious wrote:
I absolutely hate chat features and just discovered yet again I have some how enabled them on my phone....wasting my data unnecessarily and getting sent nowhere because no one I know has RCS.
I do not find that 'chat' feature on my Android Moto E4.
And if it works through Internet then what is the point having PM service at all?
Use app for phone/SMS through WiFi and save money...
10-19-2021 05:46 PM
What colour are your message bubbles? Light blue or dark blue? You may have enabled chat features by accident and if you have no data left or your mobile data is not enabled (on) you will not be able to send chat messages.
10-19-2021 04:53 PM
@t_p wrote:Something you can try:
Download and install Messages app from Google Play, set it as default and see if you can send texts with it.
Good suggestion! Messages will allow you to enable "chat features". Enabling only requires access to an incoming verification message. After that, your outgoing texts to other Messages users with "chat features" enabled will be sent through the internet, bypassing Public Mobile altogether.
10-19-2021 04:49 PM
10-19-2021 04:35 PM - edited 10-19-2021 04:51 PM
go to messages app. ..and clear Cache and Data.
10-19-2021 04:33 PM - edited 10-19-2021 04:34 PM
@roberto24 wrote:i did it before.no working
@roberto24 Contact customer support either via the chatbot or through this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
10-19-2021 04:32 PM
10-19-2021 04:31 PM
i do not have iphone.mine in android
10-19-2021 04:30 PM
that no the problem.thank anyway
10-19-2021 04:30 PM
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
and do Rebooting your phone,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
10-19-2021 04:29 PM
@Anonymous wrote:for iphone go to Settings > Messages > To turn iMessage on or off,
Turn your data on to send a Picture Messaging in world-wide,
if your data is off and your home internet wifi is on is not going through the Picture or a video Messaging,
you have to do this to is going through you will need to turn your data on to send a Picture or a video Messaging in world-wide,
make sure your Data is on.
@Anonymous OP says he's using a Motoralla phone.
@roberto24 Didn't you accept a solution (mine, as a matter of fact) yesterday with the same issue. Perhaps submit a ticket to customer support by clicking the chatbot bubble bottom right of screen to take a look at your account.
10-19-2021 04:27 PM - edited 10-19-2021 04:30 PM
