how to receive text from HK?
12-29-2024 10:26 PM
Hi,
I got lost when I can't receive text in HK? What is happening? I have subscribed long distance minutes, but I still can't receive text messages. Please help.
Service
12-30-2024 06:47 AM
@royw I have subscribed long distance minutes, but I still can't receive text messages.
Just to add, the long distance minutes only work for making voice calls when you are in Canada.
12-29-2024 10:49 PM - edited 12-29-2024 10:49 PM
hi @royw
sorry, even with the Textnow trick, you won't be able to receive any 2FA codes.
you need to contact CRA to see if they offer you other ways to receive those 2FA. Third party authentication app is the best way to choose going forward, that allows you to login CRA even you can't receive text
12-29-2024 10:45 PM
Thanks hTideGnow,
The problem is I can't receive text from CRA in order to log in to its account when I am in HK. so much problems with the verification code..., Please help.
12-29-2024 10:34 PM
sorry @royw , PM does not have roaming in HK. They only have roaming service in US and Mexico
But in HK, you can buy cheap local data there, like buy from Three, then use Whatsapp to receive messages
or you can download VoIP app Textnow while you are still in Canada. Pick a Canadian number from Textnow , then you can use that numbers to send and receive text using the app
12-29-2024 10:31 PM - edited 12-29-2024 10:32 PM
while you're in Canada, you should be able to received sms from anywhere on this mudball. Perhaps the sender isn't dialing you properly. If you're in HK...your PM service will not work at all.
ed
